Won't Start
CHRISFORTNER
  • 7 POSTS
I recently had teh wheel bearing hub changed, cv joint changed, ignition wires and ignition coil changed and gas cleaner added a few months ago
Tuesday, April 4th, 2017 AT 1:57 PM (Merged)
CHRISFORTNER
  • 7 POSTS
And spark plugs changed
KHLOW2008
  • 41,814 POSTS
Seems the idle control system is not working correctly. During startup, the IAC is supposed to increase the idling speed before settling down and this is not happening. Clean the throttle body and IAC and retest.
CHRISFORTNER
  • 7 POSTS
Ok, also when I rev my car when it runs fine, when the rpm goes down, the exhaust starts shooting out a ton of air, for like 30 seconds, u can hear it, but then goes away. Sometimes water starts spitting out the exhaust
CHRISFORTNER
  • 7 POSTS
I meant to say it starts shooting out a ton of air for like 3 seconds, u can hear it, is that normal? Because when my car is running, it doesnt shoot out a ton of air, only when I rev it and the rpm goes down
KHLOW2008
  • 41,814 POSTS
If the cold start is working correctly the rpm would be higher than idling speed and that is normal. If the problem is intermittent and not on every occsion that you start up, I would still suggest checking/cleaning the idle controls.
CHRISFORTNER
  • 7 POSTS
Ok, also when I go over bumps, like up a driveway hill or something like that, the car creaks. I think its the bushings? I just had teh struts done
KHLOW2008
  • 41,814 POSTS
Creaks can be from bushings, especially if they are worn. Other possible causes are ball joints of suspension armas or steering linkages.
If problem was not there prior to struts replacement, recheck the work done. Something could be out of place or not correctly torqued.
KSSIMPSON
  • 2000 FORD FOCUS
  • 4 CYL
  • FWD
  • 100,000 MILES
Electrical problem
2000 Ford Focus 4 cyl Front Wheel Drive Automatic 100000 miles
My 2000 Ford Focus will periodically not start. I had a problem with the key getting stuck so we replaced the ignition cylinder. That is working fine now. I had the starter checked, it's fine. Battery checked out fine. Sometimes after a half hour it will start. Sometimes it will not start for days. You turn the key and hear clicking, but that is all. Could it be possible the chip/transponder in the key is malfunctioning?
Tuesday, April 4th, 2017 AT 1:59 PM (Merged)
MERLIN2021
  • 17,250 POSTS
Clicking? Or nothing at all? If you hear a click, then either the battery is weak, or the starter, possibly bad battery cable connections, check and clean both ends of BOTH cables! Dissconnect negative(-) first, and put it on last! If no click the starter relay is no good!
RIKAJALI
  • 2000 FORD FOCUS
  • 4 CYL
  • FWD
  • 129,000 MILES
Electrical problem
2000 Ford Focus 4 cyl Front Wheel Drive Automatic 129000 miles
Raining heavily. Didn't drive through any heavy standing water. Went into a business. When I came out I turned key. Lights, everything fine. Turned key to turn over engine and dashboard lights started flashing and it went click click click. I know normally it means battery or starter. Both only 2 years old. When tow guy came it didn't start 1st time on a jump. 2nd time fine. Left car with him. Battery was fine with full charge. He said maybe starter?
RACEFAN966
  • 5,029 POSTS
Ok so you have the car or does the tow guy have it? If you have it and a have a test light or digital multi meter we can check to see if the starter is getting power if it is then I would say pull it and take it to the parts store and have them test it and buy on if it tests bad. Let me know what you want to do.
KSSIMPSON
The battery was checked at an auto place and they said it was good. We checked all battery connections and they are good. They do not appear corroded and have solid connections. I am sure I hear a clicking. Also had the starter tested and they said it was good.
RIKAJALI
I have the car. It's started perfectly since. Drove it 445 miles since the incident on highway back home.
MERLIN2021
  • 17,250 POSTS
The battery cables are now 10 years old, try jump starting the car, if it works, one or both cables are internally corroded, and has too much resistance to allow it to start.
MOLCDN
  • 2000 FORD FOCUS
  • 4 CYL
  • FWD
  • 155,000 MILES
Engine Mechanical problem
2000 Ford Focus 4 cyl Front Wheel Drive Automatic 155000 miles
tried to start the car other day it tried to fire (ruffly) then died, and it wont fire it turns over. It has fire in the plug, and you can hear the fuel pump do its thing when you turn on the key. Any suggestions what to check next
RACEFAN966
  • 5,029 POSTS
Ok so did or is the engine light on? If not then at this point there is nothing we can check as the problem needs to either be present or the engine light on to tell us what happened. Get back to me and we will take it from there.
Cranks but no start condition:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems
with compression and valves opening and closing at the wrong time/broken or jumped timing
belt/chain.
KATHYKERLEY
  • 2000 FORD FOCUS
We repalced the starter and cleaned the batetry cables
Car will not turn over
Lights work
Pick your symptom:
belt/chain.
No crank at all/nothing/nada:
Could be the starter, starter relay, clutch switch/park and neutral switch and ignition switch assuming the battery and connections are good.
