Starting problems
134,216 MILES • 1.6L • 4 CYL • FWD • MANUAL
RENé LANGøEN
My car w ill not start.
Previously i have taken out the battery, charged it all the way up, then tried again, even putting it in first gear and cranking. One time that worked and the car worked perfectly for about one week. Lets say twenty start ups, then suddenly nothing again. Only cranking. The starter was a bit stuck yesterday, i heard the click when i turned the key. So i pushed the car to some speed, and clutched it into first, letting the motor turn half a turn, then the starter was free and it started right up. Then today it would not start again. It cranks, i have checked the spark plugs, they give a nice strong spark, and are clean. The spark plugs where also moist with petrol. What more does it need?
Apr 15, 2017 at 9:03 PM
HMAC300
  • 48,601 POSTS
scan for codes and check a security system reset. see link it can be either of these or a fuel issue. but try this first.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Apr 16, 2017 at 1:38 AM
