2000 Ford Focus Vibration when first starting car in the mo
FAULL3
  • 2000 FORD FOCUS
  • 4 CYL
  • 125,000 MILES
My wife's focus vibrates and the engine is pretty loud when you first start it up when the engine is cool. Once the car has warmed up the noise from the engine calms down signifigantly, but there is still some slight vibration when stopped or idleing. I was told by one person that the fuel injector could be clogged. I bought some fuel injector cleaner and plan on using it. Does that sound right or could it be something else?
Tuesday, August 19th, 2008 AT 12:22 PM
TIMVIRGIN
I am having the same problem. Vibration is worse in the morning and when in gear (AT). Dealer acknowledged it was a factory defect, but offered no solution. Apparently there could be multiple causes including worn engine mounts, and no way to guarantee that replacing them will fix the problem.
Sunday, August 31st, 2008 AT 10:24 AM
