Car engine not starting up?
FREDDYLB
  • 1994 HONDA ACCORD
  • 4 CYL
I put a new gas pump and relay on my Honda accord 1994 and it does not start?
Tuesday, September 29th, 2020 AT 1:00 PM (Merged)
  • 109,885 POSTS
Are you getting fuel? Is the fuel pump running? Will it start with starting fluid?
FREDDYLB
Yes I get fuel. Before it started with the starting fluid, but now with the new pump it starts but when I brake the car will go off? I also put a new relay.
BLPELLEY
  • 1994 HONDA ACCORD
  • 2.2L
  • 4 CYL
  • 495,678 MILES
Cranks car but will not start when cold. May offer. Prime the engine through intake with carburetor cleaner and starts. Has to keep rpm up until warms up or will stall. When engine idles properly, did a fuel rail pressure test. Idle pressure 42 psi and 48 psi when remove vacuum line from regulator. Cleaned injector valves and did a bench test. Spray was good. Took car to Honda and did not have an adapter to do a diagnosis. Tried a temperature sensor but did not fix. Figured pulse to injector needed to be longer to apply more fuel. Are there any other sensors to increase injector pulse length or increase fuel to head?
KHLOW2008
  • 41,814 POSTS
Have the main relay checked. Quite often this relay fails intermittently and when it occurs, the fuel pump is not activated.
OLDHONDADRIVER
  • 1994 HONDA ACCORD
  • 2.2L
  • 4 CYL
  • FWD
  • 250,000 MILES
Hello, my car will crank, but will not start. Last year I replaced the starter because It was not cranking at all. After the new starter It started fine, until a few months ago. It stopped starting and would only start if I jumped it. Then I took the battery to Autozone to be checked and they said its just fine. Then I checked the oil and noticed it was pretty low and put some more in it started back on its own for about a week. Now It will not start at all, even if I jump it. Just wondering what the issue could be?
Tuesday, September 29th, 2020 AT 1:01 PM (Merged)
HARRY P
  • 2,292 POSTS
Cars need five things to start and run. (1) Gas (2) sparks (3) air (4) compression and (5) all of those being on time. Being that you were able to jump it to start it for a while, I would bet that your fuel pump is the cause of your problems. It was just a little too weak to start, but was able to get enough of a boost when it received a little extra power. But we will check several things.
First, I would check the fuses. I would buy some starting fluid from the parts store or convenience store. Just open the hood, open up the air filter duct, spray some in there (maybe one or two seconds), and then turn the key and see if it starts for a second or 2. try it several times if it does not start the first time. If it starts, or gets close to starting, then that indicates that you have a fuel delivery problem. Basically, you are not getting enough gas, if any.
If that is the case, then I would have someone turn the key on and get under the rear of the car, by the fuel tank, and listen for a humming sound for two or three seconds after turning the key on. If you hear the sound, then the pump is getting power and running. If you hear that, then borrow a fuel pressure tester from AutoZone and run a test. Here is a descriptive how to guide: https://www.2carpros.com/articles/how-to-check-fuel-system-pressure-and-regulator
Start at step 4, in your case.
If, however, you never were able to get it to start with the fluid, then you need to check for sparks. Get a spark tester This is the one that I have: https://www.amazon.com/Lisle-20610-Inline-Spark-Tester/dp/B0002STSC6/ref=sr_1_3?ie=UTF8&qid=1501325755&sr=8-3&keywords=spark+tester. Similar ones are available at the local parts store. Checking sparks is fairly straightforward on your car. Simply unhook the spark plug wire from the distributor and hook up your tester. Then have someone turn the key and see if there are sparks in there. be sure to check all four cylinders.
So check all that and let us know. Of course, if you need clarification, please let us know about that as well.
OLDHONDADRIVER
Thank you for the reply. I have a mechanic here right now working on it and he says it is the fuel pump. So it is being replaced as I type.
HARRY P
  • 2,292 POSTS
Yeah that is not surprising given the mileage on it. Feel free to come back here if you need anything else.
WILDMAN1955
  • 1994 HONDA ACCORD
  • 4 CYL
  • FWD
  • MANUAL
  • 150,000 MILES
My engine will not start. It turns over so the battery and starter are good.
I have spark at the spark plugs. I believe it is the fuel system.
How can I be sure? How do I check the filter and/or the fule pump?
F4I_GUY
  • 3,302 POSTS
You need to purchase a fuel pressure gauge with a honda adapter in order to properly test fuel pressure.
Do you hear the fuel pump priming when you turn the key to RUNII?
BOOBLAZER
  • 1994 HONDA ACCORD
  • 4 CYL
  • 4WD
  • 150,000 MILES
I was driving the car an it over heated on me but I made it home.I put water in it 2 make it home after that I let it cool off started it again it made it around the block an shut off can u tell me what I should do? Can it be the headgasket if so can I use a seal?
BRUCE HUNT
  • 3,754 POSTS
Start by making sure the engine has sufficient coolant. With the engine cool after setting for a couple of hours, remove the radiator cap and fill with coolant. Replace and fill resevoir. Now see what happens. Does it start and then shut off again?
2CP-ARCHIVES
  • 4,540 POSTS
  • 1994 HONDA ACCORD
  • 37,000 MILES
My honda is a automatic if when I turn on the ignition the sports mode indicator light on the dash flashes the engine will not start, but if it when I turn the ignition on the light go's out it will start but you never know if its going to start or not.
KHLOW2008
  • 41,814 POSTS
The PGM-FI main relay is the most common cause of this. Remove the relay and resoldering the circuit board should solve the problem.
http://www.youtube.com/watch?v=0F2OsgXmshI
Check out the link.
RENELL
  • 1994 HONDA ACCORD
  • 4 CYL
  • 4WD
  • 200,000 MILES
First I must keep pumpimg on the gas pedal in order 2 start my car well today I didnt have muck gas in my car about 2.00 worth of gas so I figured I needed more gas so I placed gas in the car and tried to start it I heard a loud pop sounded like a balloon pop and now my car wont even crank iam sure I think it may have flooded not sure wats wrong
Tuesday, September 29th, 2020 AT 1:02 PM (Merged)
KHLOW2008
  • 41,814 POSTS
Hi renell,
Unless your model is equipped with carburettors, otherwise pumping the accelerator does not do much.
You have caused a big misfire and now there are many things that you need to check.
Spark plugs, Distributor, fuel pressure. Isolate the cause then only we can get to solving the problem.
JIMENEZ 07
  • 1994 HONDA ACCORD
  • 2.2L
  • FWD
  • 186,000 MILES
Hi my Honda accord is giving me a problem when I started runs until warms up and than shutdown won't start up until cool down what can be wrong?
CARADIODOC
  • 33,916 POSTS
The first thing is to read and record any diagnostic fault codes. If there are none in memory, you'll need a scanner to view live data while driving to see if a sensor signal drops out just before the stalling occurs.
The most likely suspects are the crankshaft position sensor and the camshaft position sensor. They often fail intermittently by becoming heat-sensitive, then they work again after they cool down for about an hour.
FRANK GUIDA
  • 1994 HONDA ACCORD
  • 2.2L
  • 4 CYL
  • 163,000 MILES
Contacts on fuel relay under dash is opening and closing. Removed test plug for fuel, no fuel. Rapped on gas tank with two by four while cranking engine, it started. Replaced fuel pump, it started. A day later same problem, no fuel to engine. Have not put a gauge on fuel line yet or replaced filter. But after cranking the engine and pumping gas pedal it started. Any idea besides filter?Thank you
