starting problem
164,358 MILES • 2.7L • 6 CYL • 2WD • AUTOMATIC
JOSEPH KUMI AGYAPONG
When I turn on key to start it does not directly start, it is until I hold the key for some seconds before. My car will start up and run all day but if I shut it off it will not start right up I got to wait 15 minutes before is will start if I turn the key it do Nothing I wait then is starting?
Oct 23, 2017 at 5:09 AM
  • 110,249 POSTS
Chances are the fuel pressure is dropping when the engine is off. Try this. Cycle the switch from off to the run position three times, waiting a couple seconds in the run position before turning it back off. If pressure is an issue, that will allow the fuel pump to re-pressurize the system and then when you try to start the engine, it should go right away. Also, if you have a fuel pressure gauge, you can connect it, start the engine to check fuel pump pressure, and then turn the engine off and the pressure should hold for some time. One last thing, often times, worn plugs will cause a delayed start. It has a lot of miles, so if it hasn't been tuned up recently, that may a consideration.
Check out this guide for hard starting.
https://www.2carpros.com/articles/engine-cranks-excessively-before-starting
Please run down this guide and report back
Cheers
Oct 25, 2017 at 11:42 AM
MARCHELLE
Car is turning over will start if you hold down gas peddle, but will shut off immediately when you remove your foot. Fuel pump is kicking in with no problem gave it a tune up changed engine knock sensor throttle body positioning sensor EGR tube still doing same thing turning over, but will not start. please help me.
Nov 1, 2017 at 12:45 PM (Merged)
CARADIODOC
  • 34,415 POSTS
This is a real common problem caused by the battery was recently disconnected or run dead. The Engine Computer lost its memory and has to relearn "minimum throttle" before it will know when it has to be in control of idle speed. Until then you may need to hold the accelerator pedal down 1/4" to start the engine, you wont get the nice idle flare-up to 1500 rpm at start-up, and it will tend to stall at stop signs.
To meet the conditions for the relearn to take place, drive at highway speed with the engine warmed up, then coast for at least seven seconds without touching the pedals.
SATURNTECH9
  • 30,868 POSTS
Sounds like it is flooding have you checked for codes and checked the coolant temperature sensor?
RENEE L
  • 1,260 POSTS
Hello MARCHELLE,
If you decide you would like to conduct the scan yourself here is a link to an article that features written step by step instructions and pictures explaining how to do the scan yourself, also I have included a link to our YouTube channel with a how to video on code scanning. Most scanners are inexpensive to purchase, you can purchase one online from sites like Amazon.com
https://youtu.be/YV3TRZwer8k
Once you have the codes please get back to us so that we can further assist you. We are always happy to help.
Thank you for visiting 2CarPros.com.
All the best,
Renee
Admin
Nov 1, 2017 at 12:46 PM (Merged)
MIKOL88
Engine Performance problem
2005 Dodge Magnum 6 cyl Wheel Drive Type unknown Automatic 600000 miles
i have an 05 dodge magnum and the car wont start but theres gas in the car what could be the problem?
  • 75,988 POSTS
Try this spray some carb cleaner into the throttle body and see what happens-if it starts and dies out-check the fuel pressure. If it doesn't check the igntion system then report back your findings.
TIFFANY1900000
Noises problem
2006 Dodge Magnum 6 cyl Front Wheel Drive Automatic 77856 miles
my car wont start it just click
  • 75,988 POSTS
No crank at all/nothing/nada:
Could be the starter, starter relay, clutch switch/park and neutral switch and ignition switch assuming the battery and connections are good.
SETS
  • 5 POSTS
No problem but as I try to start car, there is no noise, no clicks, nothing. Why? First of all, a click clack kind of noise started sounding while I drove the car on the freeway. Then when I coasted, sometimes the car would just shut off, I would have to pull over, turn car off, and start it up again. This started about 2-3 months ago, sporadically.
Then, the car started to have trouble getting into gears (from P to D, P to R, D to R and back...) all the while, the click-clack noise (coming from under the hood i think) was still there... This started getting worst only about 2 weeks ago....
And now, the car won't even start. =( i turn the key in the ignition, all the lights work, windows roll up and down, radio turns on) and then I go to start the car and ...... nothing. No click, No sounds, nothing. I don't know what is going on...
Any advice?
  • 75,988 POSTS
**No crank at all/nothing/nada when key is engage to starting position
Could be a blown fusible link, the starter, starter relay, clutch switch/park and neutral switch/transmission position switch and ignition switch assuming the battery condition and connections are good. Note:If it doesn't apply disregard.
SETS
  • 5 POSTS
wow. thats a lot of options of what is wrong! lol. i tried to jump start just now and nothing... if it were the starter, wouldn't it have at least made some kind of noise or click?
  • 75,988 POSTS
If you want it fix-check and test everything I've mentioned
https://www.2carpros.com/articles/car-engine-will-not-crank-over
TOOTLE MOBILE
Last week it was idling high at red lights ...then last night just before pulling into the driveway the battery light came on then all the lights came on and the air conditioner started blowing hot air. When we parked the car shut off and won't start .... It makes a clicking sound and the lights one on but it won't turn over. The engine is new the alternator is new and the battery is new... What could this be?
DOCFIXIT
  • 18,828 POSTS
Have you opened hjood and looked at belts?
BLITZ55
I was driving, next thing i knew it went into a stall and died on me. Now it just cranks when i put the key in but it wont start. I replaced the battery and starter 1 month ago, PLEASE HELP!
SATURNTECH9
  • 30,868 POSTS
Do you have any codes?Have you checked for codes?Do you spark or fuel pressure?
  • 75,988 POSTS
-https://www.2carpros.com/articles/car-cranks-but-wont-start
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, Do you hear the fuel pump come On when you turn key on? If not check fuel pump fuse and fuel pump relay if okay-check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
KFLY70
driving about 55mph car loses power then kills try to start it up again but it would not start . it try's to start but acts if its not getting fire . thought it was a weal battery try to jump it off had no luck no codes are stored in the cpu . can hear the flue pump getting power lights work horn works . tries to start but just wont , any help would help
HMAC300
  • 48,601 POSTS
check fuel pressure with a gauge, auto parts rent them
LEGRKA
Engine problem
1999 Dodge Magnum V6 Wheel Drive Type unknown Automatic 128000 miles
WE JUST REPLACED THE HEADS ON MY 1999 DODGE INTREPIDE AFTER MY TIMING CHAIN SLIPPED SOME TEETH. KNOW WE PUT IT BACK TOGETHER AT IT TURNS OVER BUT WILL NOT START. NO SPARK. SHOULD I REPLACE THE TIMING CHAIN AND IF SO DO I NEED TO REPLACE THE TENSIONER AS WELL. ANY OTHER IDEAS TO TRY. MAYBE THERE IS A TRICK TO TIMING THE 2.7 ENGINE. ANY HELP WOULD BE GREAT.
BMRFIXIT
  • 19,053 POSTS
[quote:81c660b588="legrka"]Engine problem
WE JUST REPLACED THE HEADS ON MY 1999 DODGE INTREPIDE AFTER MY TIMING CHAIN SLIPPED SOME TEETH. KNOW WE PUT IT BACK TOGETHER AT IT TURNS OVER BUT WILL NOT START. NO SPARK. SHOULD I REPLACE THE TIMING CHAIN AND IF SO DO I NEED TO REPLACE THE TENSIONER AS WELL. ANY OTHER IDEAS TO TRY. MAYBE THERE IS A TRICK TO TIMING THE 2.7 ENGINE. ANY HELP WOULD BE GREAT.[/quote:81c660b588]
You should start investigating the no spark issue 1st
Check or replace the crank sensor
Try to get codes also
Good luck
ROLLE1976
Engine Mechanical problem
2006 Dodge Magnum 6 cyl Two Wheel Drive Automatic 44650 miles
my magnum wont start and it is not the battery cause I tried to jump it, it did not have any problems before today. It turned on and shut off right away and I did that twice then it just wont do nothing know
  • 110,249 POSTS
Hi:
Have a helper turn the key to the start position while you check for power to the smaller wire on the starter. You should have 12 volts. Let me know what you find.
NYCHAMP12
2006 Dodge Magnum 6 cyl Two Wheel Drive Automatic 39,300 miles
i have a 06 magnum 2.7l engine and when the car sits overnight and i go to start it it has trouble starting. it to the dealer and they did a test on the battery, alternator and starter and it checked out fine and they also checked out the fuel system and that also checked out fine. it only has trouble starting when it sits for more than 4 hours.
SERVICE WRITER
  • 9,123 POSTS
Can you explain the symptoms clearer?
For example:
Does it turn over a lot before it starts?
Does it turn over real slow?
DJBSLW82
I have a 2005 dodge magnum se 2.7. WS running fine than went to store turned it off to run inside and when I came back it wouldn't start. I have changed the pcm....alternator.... And fuel pump on the left side. I have had the battery checked out and that's fine. Won't turn over it Just a hard crank. Please help
Nov 1, 2017 at 12:47 PM (Merged)
  • 110,249 POSTS
What do you mean by hard crank? Does it sound differently when the starter is engaged? If so, have you checked timing?
DJBSLW82
Yes it sounds different than a normal start. The timing belt? I didn't think if that since it had to e loosen to take the alternor off. IDK Im lost with this car. It's too nice of a car to let it go. Doesn't sound like fuel pump is turning on when tryin to start the car that's y we changed the fuel pump
  • 110,249 POSTS
Since it sounds differently, check timing. If I recall, this year has a chain which usually won't break. However, I have seen them jump a tooth.
Let me know what you find.,
DJBSLW82
But could timing come off on it's own? I mean b4 we replaced the alternator
  • 110,249 POSTS
Yes, a timing chain could jump a tooth.
SHANIEKA
Transmission problem
2004 Dodge Magnum V6 155258 miles
what could be wrong?
  • 110,249 POSTS
This may sound funny, but are the brake lights working? The park lock solenoid is actuated by the brake light switch.
DISHEXPRESS01
Have a 2005 Dodge Magnum 3.5. Have a problem starting car. It is an issue with the security system or some computer system. If i lock doors as normal and unlock doors and enter vehicle and put key in and turn key. There are NO lights (absolutely no dash lights) on dash and nothing when I turn the key. If i do the same procedure and turn the key and wait aprox 10 seconds the lights on dash will come on and car will start. Then usually the car will start several times after that. I have ordered an duplicate key, changed ignition switch, change immobilizer and same thing. I have brought it to dodge dealership and they told me it was a bad front body control module and integrated power module. I changed that had it programmed and still same symptom. Please help
CARADIODOC
  • 34,415 POSTS
Here's the major clue:
"There are NO lights (absolutely no dash lights) on dash and nothing when I turn the key."
Follow the smaller positive battery wire to the under-hood fuse box and be sure that connection is clean and tight. That connection is responsible for intermittently dead electrical systems on almost all car brands and models.
PSHALL
I have a 2005 dodge magnum and my problem is with starting the vehicle. turn the key...engine starts and dies right away. battery still good, seems like bad connection?
  • 75,988 POSTS
Do you have a check engine light?
Check the fuel pressure with a gauge if its within specs and check the idle air control motor -start here
BAYFIELDKID
Just had that problem with my 2005 Magnum. turned out the battery holder in key broke and it fell over on to the sensor that activates the antitheft alarm. I was lucky enough to take it apart clean and repair it. otherwise you are looking at least 200.00 for dealer to recode key. Try that or disconnect battery to reset alarm. There are several forums that discuss "our" very problem... Good luck... So much for the "expert" Let me know what happened..
SIDNEY26
2005 Dodge Magnum 6 cyl All Wheel Drive Automatic 103086 miles
i have a 05 dodge magnum. just recently, i have had problems starting the vehicle. the radio, the lights, and heater will come and it will not turn over. i found at one time, if i touched the brakes, it would start. now i have to play around with the steering wheel for the car to start. this does not happen all the time. i have had the cables to the battery checked but not on a tester. i have noticed if the radio or cd was left in it takes longer to start. now my seat warmers will not come on. the engine light will come on briefly as well as the anti theft red light and it will not give a code. i havent had to call for a tow truck bc it will eventually crank the shortest 1 minute the longest 20 minutes.
