Have a helper crank it, while you visually check for spark at the plugs. You can take a spark plug wire loose, use known good spark plug or spark tester in the boot, ground metal part of plug/tester to metal part of engine. Engine cranking, watch for spark. If you have spark everywhere, you might try some starter fluid in the intake? Take air breather off, open the choke valve, spray a small amount of stater fluid in the carb. Stand back from the vehicle, have helper crank, see if it tries to start?
My info shows your computer controlled, check for any applicable trouble codes.
SPONSORED LINKS
Friday, July 24th, 2020 AT 12:29 PM
(Merged)
