Have someone remove gas line at carb or injector inlet. Turn key over check color of gas for water and trash , check pressure,
if not enough gas replace filter inside frame
rail passenger side, not enough gas
pitched lines on top of gas tank, from gas pump inside tank, pump has a filter on it also inside tank, tank had to be dropped and cleaned.
Frogslips
Friday, August 22nd, 2008 AT 11:01 PM
