Engine is a no crank over?
SATURNTECH9
  • 30,869 POSTS
So what did you find from the trouble tree I posted.
Monday, January 25th, 2021 AT 9:47 AM (Merged)
SSHDSILVERADO
  • 15 POSTS
Every nthing it says is pointing to a bad pcm. But it troubles me with not having the security light come on at all. Im gonna try to remove ignition switch and @lean contacts its almost like the bcm is not getting signal
SATURNTECH9
  • 30,869 POSTS
Yeah thats the feeling I was getting also you can try to clean the contacts and see what happens. It would be nice if you could read the pass lock enable code.
SSHDSILVERADO
  • 15 POSTS
Do you have the removal procedures for the ignition switch or a test tree on it
SATURNTECH9
  • 30,869 POSTS
The trouble tree I gave you has the checking of the ignition switch its one of the first steps after checking the pass lock enable status.
SSHDSILVERADO
  • 15 POSTS
What I was wondering was if the switch was relaying the signal to the bcm for the pass lock feature I only see to use the scan tool for it im trying to chase wires fun fun to check continuity but I would like to remove the key switch to check the pins on it but not sure on what and how to remove it
SATURNTECH9
  • 30,869 POSTS
On that car the security system will disable the fuel injector pluse not the starter. To check the ignition switch put the key in the start position if you have power out of the big yellow wire out of the ignition switch the switch is working. The problem I saw was the pcm was giving a power signal to the crank relay instead of a ground so power goes to the starter.
SSHDSILVERADO
  • 15 POSTS
I know its been awhile summer vacations weee. Ok been doing some digging on wires found a singal black wire from ignition switch to steering harness plug connector. That looks like it got very very hot trying to find a wiring scamatic for this conector and where it goes any ideas thank you
