2000 Venture Van 3.4L 218,000 KM Will Not Start
FISHINGCAMY
Van turns over but will not start. Hit gas tank with hammer and fuel pump started working and started.Changed fuel pump and van ran for a couple of days and would not start again. Could it be a defaulted fuel pump or the fuel relay.
Sep 14, 2007 at 5:08 PM
SERVICE WRITER
  • 9,123 POSTS
IT may be a bad fuel pump again..wouldn't surprise me. I assume you changed the filter at the same time...if not should have. get a good look at the connector and make sure there is no evidence of any corrossion or such.
Check the fuel pressure if possible. I have seen back to back no starts with different reasons.
Sep 15, 2007 at 3:54 AM
SERVICE WRITER
  • 9,123 POSTS
I hear you found an electrical problem, can you elaborate?
Sep 15, 2007 at 9:47 AM
