Crank angle sensor location please
TABJR
  • 5 POSTS
Car haves 3.8 with cap. Motor mount boke repair and put new water pump car cranks but will not start?
Saturday, March 2nd, 2019 AT 11:43 AM (Merged)
SATURNTECH9
  • 30,869 POSTS
If you have a cap there won't be a crank sensor. So it ran good before you replaced the mount and water pump?Did you check to see if you knocked any wires loose?Have you checked for spark and what your fuel pressure was?
TRAVIS RASMUSSEN
  • 1992 FORD TAURUS
  • 6 CYL
  • FWD
  • 150,000 MILES
WERE IS THE CRANK SENSOR
BMRFIXIT
  • 19,053 POSTS
On lower right rear of engine
TABJR
  • 5 POSTS
Car will not start see antifrezze leaking out of muffler
JGAROFALO
  • 489 POSTS
There is no crank sensor on a 1992 Taurus. This car has a distributor.
SATURNTECH9
  • 30,869 POSTS
Pull your oil dipstick out see if there is coolant in the oil if there is it usually will make the coolant look milky white. Also pull all the spark plugs out and see if there is coolant in your cylinders.
TABJR
  • 5 POSTS
Thankyou have crack block.
SATURNTECH9
  • 30,869 POSTS
Your welcome that's what were here for. Also thank you for using 2carpros.
WILDCOUNTYR61
  • 1996 FORD TAURUS
Where is the ckp senor on a ford taurus and wher does the two leed wires coming from the ckp senor go?
ERNEST CLARK
  • 1,730 POSTS
I'll need to know what engine you have in your car to tell you where the CKP sensor is located. The wires coming from the sensor go to the computer.
