2002 Ford Taurus 02 taurus cuts off when i get on brakes
150,000 MILES • 6 CYL • FWD • AUTOMATIC
TJONES1
I'm having problems with my 02 Ford Taurus cutting off like its not getting gas. Once i get off my brakes it cut off but will crank back up. It does it about 2 or 3 times while I'm driving. The machanic changed the crank shaft position sensor because it was making a loud noise; he also changed the fuel filter. Thought that was the problem but it continued to cut off. Please help! Thanking you in advanced!
Oct 9, 2010 at 4:54 AM
  • 110,246 POSTS
Has the fuel pressure been checked?
Oct 9, 2010 at 6:16 AM
TJONES1
I dont know but if that's not the problem, what else to check for?
Oct 9, 2010 at 6:56 AM
TJONES1
to answer the 1st question, yes the fuel pressure has been checked.
Oct 9, 2010 at 7:46 AM
  • 110,246 POSTS
There are many sensors that could cause this. Has the check engine light come on? With the new crank sensor, has the noise stopped?
Oct 9, 2010 at 4:10 PM
TJONES1
Yes, the noise stopped and no the check engine light is not on nor has it ever came on but my car is still cutting off when i get to a stop sign or try to put it in gear.
Oct 12, 2010 at 2:04 AM
  • 110,246 POSTS
Remove the idle air control motor and see if it is clean and working.
Oct 12, 2010 at 2:10 AM
