Crank no start?
  • 109,921 POSTS
For some reason, the other parts of this thread are missing. So, I have to ask which control valve you are referring to.
Wednesday, July 19th, 2023 AT 8:32 PM
TAMMYRL
  • 18 POSTS
This is where I am talking about will try to highlight toward the end the relief valve. Injection is supplied by the high pressure fuel pump manifold and is driven by a three-lobe cam on the ca or in the form of an internal solenoid-controlled valve engine control module (ECM) requests pressure Output drivers in the ECM provide the high pressure n regulates fuel pressure by opening and closing the portion of each pump stroke that is delivered to t ease in fuel pressure when the control solenoid is N ed by a relief valve in the pump that prevents the pr.
Wednesday, July 19th, 2023 AT 8:50 PM
  • 109,921 POSTS
I believe the control valve is integral to the pump. I don't feel it is a separate unit.
Thursday, July 20th, 2023 AT 6:08 PM
Related Engine Not Running Content
