Engine cranks but no start up?
  • 109,885 POSTS
Have you checked to see if you are getting spark when it doesn't start? If you smell fuel, chances are you're not getting spark. If that is the case, the crank sensor may be going bad. Has the check engine light come on?
Tuesday, December 29th, 2020 AT 11:46 AM (Merged)
CHRIS R. GRAHAM
  • 2004 FORD EXPLORER
  • 4.6L
  • V8
  • 250,000 MILES
I went to a Murphy's at my local Walmart. Got gas. Literally moved about 20ft into the parking lot and shut off engine. Played on my phone for a bit (checking bank statement, etc, ) tried to crank up and nothing happened. Over a course of 3 days I replaced battery, alternator, and starter still no start. Attempted to jump start it and still no start. All it does is crank crank crank when I turn key but will not start.
A little back story on it, the serpentine belt did snap on it few days before the no start incident began due to loose compressor. Tightened down the compressor and replaced the belt the following day. Before I could replace belt I was stuck in the middle of town with my wife, 5 year old and 7month old in 40 degree weather at about 10:00pm so no store near me was open, so I had to drive home with no belt. What can be causing my crank, no start problem?
I don't think any of that is related. However, we will come back to it if needed.
Let's start from the beginning when we have a crank no start issue. Here is a guide that we are going to walk through to figure this out:
https://youtu.be/dCjmRL3p4Cs
I want to start with using starter fluid in the intake and just crank the engine. So pick some up from a parts store and then spray it in the top of the housing for the air filter. Not through the air filter, but on the engine side of the air filter housing. Then just crank the engine and see if the engine starts for a second or two.
If it does then we need to check the fuel pressure. Here is a guide that tells us how to do that:
If this doesn't do anything then we need to check for spark but let's address the fuel first because I think that this is the issue.
Let me know what questions you have. Thanks
MIKEBKFD
  • 4.0L
  • 6 CYL
  • 4WD
  • 179,000 MILES
My vehicle listed above is having problems with the throttle. I have change the throttle positioning sensor, the actuator motor that's on the throttle body, oil change. The pedal positioning sensor all it does when you turn the key to the on position is that actuator motor clicks three times and then no accelerator pedal what so ever. It has happened three times now; first time is left me stranded for three days the other time just two hours and now two weeks. I've checked all fuses relays and wiring that I can get to and I put a different computer in it which I knew would not start it. It did the same exact thing the three clicks when you turn the key on and then nothing. The actuator motor makes a bunch of clicking noises when you start it and then continues to making those noises. I don't know what's going on, but I need my car back.
Tuesday, December 29th, 2020 AT 11:49 AM (Merged)
This could be a number of things but we need to start with checking for codes. If we have codes then that will point us in the right direction and give us the testing that we need to perform.
I am thinking we have potential accelerator pedal position sensor codes or some other codes that are disabling the throttle.
Let me know what you find and we can go from there. Thanks
MMCCUNE1973
  • 150,000 MILES
I changed harmonic balances on sohc 4.0. The wood-ruff key did not go in right so when I tried to start it after I put it back together the key was not holding the timing gear, so the crank turned but not timing gears. I took it back apart get the key grooves lined up again and put new key in and got it back together correctly. But now it will not start. I tried taking it back apart and turning the crank 180 degrees on the timing gear and put the key back in, but it still will not start. Someone please help!
STEVE W.
  • 13,573 POSTS
Stop trying to start it. That engine is an interference engine. That means at the very least you have some bent valves. At worst you have a scrap engine. It will never run as it currently is. You have the option of trying to repair it or replacing the engine. Your choice.
