2004 Ford Explorer NO throttle response 2004 ford explorer
61,000 MILES • 6 CYL • 4WD • AUTOMATIC
MIKE6898US
2004 ford explorer xlt v6 4.0 61000 Disconnected and reconnected the connectors on the intake Then wouldn't start right away but when it did there is NO throttle response and the idle is weak whats could be the problem
Dec 30, 2007 at 4:56 AM
2CARPRO JACK
  • 11,533 POSTS
What connectors? Is everything plugged in? The MAF in the air box? TPS on the side of the throttle body? If so, look in sensors to be sure a pin didnt roll over
Dec 31, 2007 at 1:08 AM
