Car wont start getting fuel but no fire and no signal tothe coil pack or any other sensors
Wednesday, August 27th, 2008 AT 12:04 AM
BLACKOP555
MECHANIC
Since the injectors are pulsing it sounds like the camshaft sensor is good, but since no fire from the coil.
Really sounds like the crankshaft position sensor needs a replacement and relearn.
Any check engine lights or codes stored?
Wednesday, August 27th, 2008 AT 8:57 AM
GREENFAMILY
MEMBER
What would you think if the scenario were similar where the explorer 2004 4.0 sohc would crank and pulse the injectors, but I only have spark present on the 4-5-6 side of the coil tower and nothing from the 1-2-3 side of the coil tower?
Tuesday, February 2nd, 2010 AT 1:54 PM
BLACKOP555
MECHANIC
What kind of setup is your vehicle. Coil on plug?
Check for voltage to all of the coils.
You can use a t-pin and check the ground side for a pulse signal on that side by using a logic probe on the tpin'
this will tell us if its coil issue, power issue. Or icm/computer.
