Ok, lets say you dont have power on pin B of the solenoid with the ignition switch on. Go back to the fuse that you had to replace, and remove it. Check for power at that fuse with the ignitions switch on. If you dont have power to the fuse, suspect a bad ignition switch or a break in that line.
Now, if you did have power to the fuse, but no power to the pin B at the soleniod, you must find the break in that line.
According to the manual, this DTC 13 code is set when the Engine Shutoff Solenoid has a circuit fault. The next part I am going to type is a cut and paste from the manual. If you email me at Michael.D. Byers@Delta. Com I can send you diagrams.
CIRCUIT DESCRIPTION
When the ignition switch is in the "OFF" position, the engine shutoff solenoid is in the "No Fuel" position. By providing a ground path, the Powertrain Control Module (PCM) energizes the solenoid which then allows fuel to pass into the injection pump.
DTC 13 WILL SET WHEN
Ignition voltage on terminal "E16" when PCM is requesting engine shutoff solenoid "ON."
ACTION TAKEN (PCM will default to)
A current and history DTC 13 will be stored.
DTC 13 WILL CLEAR WHEN
The fault condition(s) no longer exist.
DTC CHART TEST DESCRIPTION
Number(s) below refer to circled number(s) on the diagnostic chart.
Check for open circuit from ignition switch to the solenoid.
Check CKT 981 from solenoid to PCM for open.
DIAGNOSTIC AIDS
An open in CKT 981 or 339 will cause a DTC 13
Also a no start condition will exist.
SPONSORED LINKS
helpful?Yes
Tuesday, July 25th, 2006 AT 2:33 PM
