1994 Chevy Truck Electrical or Engine Probs
MEGAN48867
  • 1994 CHEVROLET TRUCK
  • 6 CYL
  • MANUAL
  • 207,000 MILES
Wont start-
Turns over-
front running lights are dim when battery is hooked up even when they are turned off!
Starts firing with starting fluid but wont stay running.
Saturday, March 14th, 2009 AT 12:16 PM
JDL
  • 16,098 POSTS
Hello, make sure the battery and cables are in good shape. Check fuel pressure, TBI about 10 psi. Check for troublecodes, your obd1, you should be able to check codes yourself.
Saturday, March 14th, 2009 AT 12:25 PM
MEGAN48867
I am going to check the TBI and Trouble Codes. I have checked all the rest! Thank you for your response. I will be in touch with the progress!
Saturday, March 14th, 2009 AT 12:51 PM
