Starter not working?
TOMSTEVE
  • 1993 BUICK LESABRE
  • 120,000 MILES
Ok, this is a friends and I dont know much about buicks. The car cranks over strong, theres spark. Cant say how good as it was late, dark, and raining when he called( used a screwdriver in a plug wire) and I went to see what I could do. He had drained the battery so I jumped it. It rolls over strong but acting like no fuel. He says this happened once last spring and the car had to sit for a few days before it would start, then didnt have a problem til tonight. One thing I did was disconnect the ground on the battery( and I cant even remember why, but there was a reason) and after I hooked it back up, it sputtered for a second then nothing.
Any suggestions on where to start?
Thursday, August 6th, 2020 AT 10:20 AM (Merged)
  • 52,797 POSTS
Check fuel pressure first.
TOMSTEVE
Im at 42 psi.
TOMSTEVE
Got it runnin. Unplugged the mass air flow sensor and the other 2 connections by it and it fired right up. Pulled the mass air flow sensor and cleaned it with mass air flow cleaner. Thinkin a new one is in order.
BILBONE
  • 6 CYL
  • FWD
  • 138,000 MILES
My car will not start, the solenoid will not even click with the key. The starter and solenoid work fine when I hot-wire it to the battery, however the car will still not start with the key in the on position when I do this. I also checked the fuses and they seem to be fine.
MASTERTECHTIM
  • 4,750 POSTS
Is the security light on solid on the dash?
LOCALPOD
Electrical problem
1993 Buick Lesabre 6 cyl Two Wheel Drive 76568 miles
stater cable came off and was reconnected but stater would not kick in as though it was not getting any fire
JDL
  • 16,098 POSTS
I'd have to make sure the battery has a full charge and the connections are good. Is the theft/security lite on the dash, on or flashing, when you try to start? Any codes?
