Ok the relay #3 didn't change anything I even bought a brand new one is it possible that isn't the slot for it? The Crank sensor is plugged in what else could I check?
Tuesday, December 20th, 2016 AT 11:11 AM
BMRFIXIT
MECHANIC
Disconnect connector from camshaft position sensor (ignition distributor)
check ohm between terminals 1+2
1+3 maximum resistance 1.5 ohm
if not replace
PITT51
MEMBER
Ok checked the terminals on distributor and checks out good. Now what could I check? Remember i'm getting no spark.
BMRFIXIT
MECHANIC
Need to scan for codes
you had checked and tested every thing possible
have to check for codes
lets see what or where that will take us to!
PITT51
MEMBER
Is there any way of jumpering some thing to get the codes with out scanner?
BMRFIXIT
MECHANIC
Sorry I dont know of any if there is any
your is an OBDII ready check at your local part store if you can rent one .
**Is security light on ?
try to lock and unlock the door or the trunk using the key
