My transmission will not engage why?
YOUNG MICK
  • 8 POSTS
  • 1998 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 96,000 MILES
Will not shift into drive, when I start out. Any ideas out there?
Friday, May 21st, 2021 AT 12:13 PM (Merged)
BILLYMAC
  • 2,204 POSTS
Hi billymac here. Two things it could be the most likely is input and output sensors. These are two sensors on the front of the trans not that bad to get too in this vehicle. They are less then 20 dollars a piece. Change them and disconnect the neg cable for 5 mins or so and test drive. The other thing is the trans computer this is mounted under the hood. There will be two computers together one is for the trans the other for the eng. These are around 100 dollars. Before you buy any parts smell the trans fluid if it smells burnt trans is failing. Hope this helps billymac
YOUNG MICK
  • 8 POSTS
Billymac,
Thanks for the imput, I will try the sensors first.
I will get back to you!
Thanks again,
Ypung Mick
AMY SAPP-AMOS
  • 1997 DODGE CARAVAN
  • 2.3L
  • 4 CYL
  • 160,000 MILES
Transmission does not want to engage when gas is accelerated. On dash panel shifting indicator was broken. What is the problem?
Friday, May 21st, 2021 AT 2:48 PM (Merged)
STEVE W.
  • 13,573 POSTS
Check the fluid level and color. If it is low or burnt it can cause this. It is also possible the filter has come loose, Chrysler has an issue with that.
AMY SAPP-AMOS
The fluid level was showing that it was overfilled. So they siphoned about half a quart thru the dipstick part. Still having same results. Seems better once it warms up. But also having electrical problems with brake lights and blinkers. Wipers occasionally turn on by themselves. Check engine light is on and reads a sensor to do with emissions is faulty. Help please!
STEVE W.
  • 13,573 POSTS
Well the electrical issues sound like the multi-function switch or it's wiring. You mentioned the indicator doesn't work as well. Did you buy this van new or used? If used it's possible someone else was under that dash. Does this van have remote door locks or start?
Emission codes are common as well. Post the actual code, as very seldom do the codes actually point to a sensor, usually it's a faulty circuit or a different issue causing the sensor code. The code at least gives a starting point.
