1995 Dodge Caravan Slips
JPW
  • 6 POSTS
Transmission problem
1995 Dodge Caravan 6 cyl Front Wheel Drive Automatic
I have a 1995 Dodge Caravan SE, with a 3.0 motor,
four speed overdrive transmission.
This (trans) was rebuilt 3.5 years ago.
When you drive the van the transmission after it warms up slips from D to 2nd gear, sometimes when you stop and start it the transmission will not go into drive. when you pull over put the van in park and re-start it it is fine.
when you drive it for long periods of time it gets worse. You have to keep pulling over shutting it off and again re-starting it.. Please help, any answer's ?
Thanks
Apr 10, 2009 at 8:31 AM
BMRFIXIT
  • 19,053 POSTS
Suspect speed sensor and or solenoid pack
have to scan for TCM codes
do you have check engine light on ?
check Tranny fluid
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
_________________
Apr 10, 2009 at 11:23 AM
JPW
  • 6 POSTS
Yes the check engine light does come on but is not on at all times. Sometimes its not on for some-time then it will re-appear .
Is the speed sensor the input seed or output speed sensor? Thanks again
Apr 10, 2009 at 3:05 PM
BMRFIXIT
  • 19,053 POSTS
codes can determine that for you
if not i would replace both easy enough
Apr 10, 2009 at 11:57 PM
