1999 dodge caravan has 106000 miles. trans runs fine in drive but won't go into reverse.
May 12, 2006 at 6:19 AM
Have a transmission specialist perform a computer diagnostic check. Loss of reverse may indicate early transmission failure, or possibly a faulty reverse solenoid.
A 1999 Dodge Caravan with 106,000 miles drives normally but will not go into reverse. The expert said this is often an early sign of transmission failure, though a reverse solenoid could be the cause, and recommended a computer check by a transmission specialist.
