My truck shut off and will not crank up
170,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
MELGAR
My truck shut off and will not crank up. what would cause this?
Apr 8, 2018 at 1:58 AM
good morning.
This sounds like the crankshaft angle sensor or the fuel pump has gone out, when you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds?
Aug 14, 2020 at 3:05 AM
MELGAR
The guide showed a bad PCM does the theft module have to match the PCM and key or can I leave that alone?
theft module should be good. just the PCM and programming.
Aug 14, 2020 at 3:06 AM
MELGAR
Okay, do I need to change the whole switch out or just a key and PCM?
no, the PCM has to be changed. your existing key will be programmed to the replacement PCM. no need to replace anything else.
MELGAR
Thank you I got a new PCM started right up thank you.
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help.
