2001 Ford Ranger
08EHLMANM
  • 2001 FORD RANGER
2001 Ford Ranger 6 cyl Two Wheel Drive Automatic
The truck will crank some times but will not start the fuel pump is also running when I crank it, also some times it wont even crank and it has a brand new battery in it what could it be?
Sunday, October 4th, 2009 AT 4:33 PM
  • 109,885 POSTS
Have you checked to see if it is getting spark?
Wednesday, October 28th, 2009 AT 8:52 AM
STEVEDUNN46
WHY THE CONCERN ABOUT IT GETTING SPARK WHEN SOMETIMES IT WILL NOT EVEN CRANK?
Wednesday, October 28th, 2009 AT 3:00 PM
  • 109,885 POSTS
So many people refer to the word "crank" as starting. I wasn't sure what you were refering to.
AS far as the cranking, when you have this problem, have a helper turn the key to the start position while you check for power to the smaller wire at the starter. Let me know what you find.
Thursday, October 29th, 2009 AT 7:23 AM
