86 Toyota tercel Wagon 4x4
FIZIZIVE
I have this toyota I put gas in it drove it to the dump back to the house and was headed back out to a friends house ... The car quit it was acting like it was starving for gas ... I pulled the fuel filter and blew it out and poured the gas out of it put it back in turned the key on then started after a minute but died .... i have a fuel pump on the way but where is it is it electric or other.....Please help someone wants to buy!!!!!!Sorry can't donate till sell !!!!!
Dec 19, 2006 at 9:24 AM
BACKYARDMECHANIC
  • 337 POSTS
I don't know your car very well so I can't tell you where the pump is, if it's electric, or a mechanical. However this may help
1) Is the car fuel injected. If it is you have a electric pump. It will be located in the gas tank. I know what a bumper to change.
2) you can also check for a fuse for the pump. If you have a fuse you have an electric fuel pump.
3) If its a mechanical pump then you will have a carb.
4) If its a mechanical pump is located on the block and is operated by the cam shaft. Hope I've been helpful. Backyardmechanic :?
Dec 19, 2006 at 9:42 AM
