1991 Toyota Tercel Follow Up
TRISHELLECAR
Noises problem
1991 Toyota Tercel 4 cyl Wheel Drive Type unknown Automatic 156880 miles
My brother looked at it and he thinks it might be a loose exhaust.
Mar 1, 2008 at 12:03 PM
BLACKOP555
  • 10,386 POSTS
What seems to be the symptoms or the problems then i will be able to give you my oppinion.
Mar 1, 2008 at 12:27 PM
TRISHELLECAR
My brother says that the problem is with the exhaust. A bolt was missing. The previous symptoms I had described were a rattling noise when it starts and seems to disappear after I hit 35 mph. While the car speeds up, the sound gets louder. If you can suggest what kind of bolts are needed or qhere to get them it would be greatly appreciated. Thanks in advanced!:)
Mar 1, 2008 at 3:49 PM
BLACKOP555
  • 10,386 POSTS
sounds like an exhaust problem, you will have to go under there and check all the hangars and heat shields to see if they are loose and let me know what you find.
Mar 1, 2008 at 11:59 PM
