Car shut off and would not restart
MZEE
  • 2003 TOYOTA RAV4
  • 2.0L
  • 4 CYL
Engine has failed to start, there is no spark to start engine.I have checked wiring is okay
Tuesday, August 20th, 2019 AT 12:18 PM (Merged)
CARADIODOC
  • 34,100 POSTS
Have you checked for fuel pressure? What about reading the diagnostic fault codes?
Wiring problems only cover about half of the list of possible causes. Since you're checking for spark, I assume "failed to start" doesn't refer to the starter failing to crank the engine. The most common suspects are the crankshaft position sensor and the camshaft position sensor. The fault codes will indicate which circuit or system needs further diagnosis.
CHABONAL
  • 2004 TOYOTA RAV4
Electrical problem
2004 Toyota Rav4 Four Wheel Drive Automatic
alternator got busted couple of weeks ago. They had it fixed, and now it wont start again and they said its the battery. Is it because of what happened w/ the alternator or they just didnt fixed it well that it damages the battery? Tnx
The alternator could be defective and not reconditioning the battery or the battery is sulfated not taking the charge
BIGALBIE
  • 2001 TOYOTA RAV4
  • 4 CYL
  • 131,003 MILES
Car was working fine I changed ground cable and terminals now the car just turn over but doesnt start
LOSTINMARS
  • 222 POSTS
Damn dude you didn't even bother looking around here 1st....don't worry i'll do it for you.
https://www.2carpros.com/forum/2003-toyota-rav4-replaced-battery-and-now-wont-start-vt91390.html
KMIG
  • 11 POSTS
  • 2000 TOYOTA RAV4
It has spark-fuel-and timing belt turns.I code tested found a code po340 camshaft position sensor malfunction did oms test on sensor it seemed ok. Opion if you have one thanks alot
GFIMOTORCARS
  • 673 POSTS
With this code and a crank no start condition you are more than likely looking at a failed camshaft position sensor. This is a fairly inexpensive part ($80-100). Checking resistance (ohms) of the sensor your range should be between the following and not at either extreme, as this is an indication of coming failure. If it is cold where you live
-10-50deg F, then your range is 985-1600ohms
50-100deg F, then your range is 1265-1895ohms.
Keep in mind you can have a failed component that tests good ohms.
