Trying to start on its own
160,550 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
VARRO
Put a new battery in when hooking it up Car tried to start itself did some research people said to replace the ignition switch did that did not solve the problem I pulled the starter relay out and it stopped the problem when you have to post on the battery cable up and stop trying to crank could the starter relay be the problem I have no idea any suggestions would be very grateful
Jan 1, 2016 at 12:02 AM
HMAC300
  • 48,601 POSTS
It may need a starter as solenoid may be sticking when you put relay in.
Jan 1, 2016 at 1:13 AM
VARRO
Thanks i will give that a try
Jan 1, 2016 at 2:06 AM
