running rough on 3 cylinders
EGAZ11
Engine Performance problem 4 cyl Two Wheel Drive Automatic 160000 miles
One morning i started my car and it was running on 3 cylinders- rough idle, poor acceleration, hesitating when giving gas. I replaced all the plugs and found a fouled plug in #3 but no improvement in power or idle. The check engine light code read misfire on #3 cyl. I have put two bottles of Lucas fuel injector cleaner in two full tanks and no help. Its not running hot and sometimes runs ok at higher speeds. Coil ? f injectors? cat converter? plug wires? What can i do?
Apr 28, 2010 at 9:26 AM
  • 75,988 POSTS
Yep first check to see if the #3 coil is working here is a guide to help you confirm.
If it has spark lets check compression and then fuel injector operation here is a guide that will help you walk down the problems using easy tests.
Cheers
Apr 28, 2010 at 10:13 AM
EGAZ11
Yep it was low compression my mechanic said it has a burnt exhaust valve and will cost 800.00 to fix. I will need to park it for while. Thanks for the help the guides are great.
Apr 29, 2010 at 10:03 AM
