Will not start
FRAMESCR8PINTOY
Stupid question, but how do I go about doing that?
Sunday, July 22nd, 2018 AT 1:46 PM (Merged)
MARYANNLANE1
  • 10 POSTS
Well, while doing the tests you mentioned, we noticed that when cranking the engine, the rotor does not move, time gear belt busted?
BROOKS AUTOMOTIVE
  • 5 POSTS
  • 1991 TOYOTA PICKUP
Four cylinder two wheel drive manual.
I did a head gasket now it will not run. I have spark and fuel.
You probably did not align the cam and crank properly.
You need an ohmmeter to check for resistances/continuity.
RACEFAN966
  • 5,029 POSTS
Well, I would say that if the distributor rotor does not turn that yes the timing belt is probably broken. You will have to pull the upper belt cover and check to see if the belt is turning when cranking or not. Here is a picture of what all is in there. If you find a broken belt I would plan on the belt the tension-er and idlers and water pump sense the belt drive the water pump.
https://www.2carpros.com/forum/automotive_pictures/249564_Graphic_165.jpg
BROOKS AUTOMOTIVE
  • 5 POSTS
How can I make sure that the timing is set right?
MARYANNLANE1
  • 10 POSTS
After I replace the belt what are the timing positions for the crank and drive shaft?
Put the engine's number one piston on its compression stroke/TDC then align it-remove the distributor and restab it and make sure rotor is pointing to the cap number tower as indicated in the repair manual.
https://www.2carpros.com/forum/automotive_pictures/12900_timing_13.jpg
RACEFAN966
  • 5,029 POSTS
Here are the timing marks. If you need anything else just let me know. Also let me know the outcome okay.
https://www.2carpros.com/forum/automotive_pictures/249564_Graphic1_19.jpg
https://www.2carpros.com/forum/automotive_pictures/249564_Graphic_166.jpg
BROOKS AUTOMOTIVE
  • 5 POSTS
Where is the crank mark supposed be is the key on the crank?
MARYANNLANE1
  • 10 POSTS
Thanks got it running, but still runs a little rough. How can I adjust it so it runs smooth? Plugs and plug wires are new, spark plugs are gaped properly, new igniter and coil and distributor and rotor. Was timed digitally, so anything else I can do?
YOTAGUY
  • 4 CYL
  • MANUAL
  • 150,000 MILES
Once a day, maybe twice but mostly first starting after it has sat for a while the truck will not start. No cranking, no nothing. Then once I turn the key off and try again it starts fine and the problem will not duplicate again for a while. Does not seem like a loose connection kind of issue. Was thinking starter relay or safety switch? Maybe solenoid?
The timing mark is on the crankshaft sprocket should be position six o'clock. Are you using a repair manual or just playing it by ear?
KHLOW2008
  • 41,814 POSTS
Hi yotaguy,
Could be:
1. Ignition switch.
2. Solenoid, could be loose wire.
3. Starter. Carbon might be running low or contaminated. Additional clicking of the solenoid sometimes makes it work.
RACEFAN966
  • 5,029 POSTS
Okay, if you would do a compression test just so we know where it all stands. These engines do have a head gasket problem on the right (passenger) side. Most are on recall. So first things first check compression and lets take it from there.
JTMESS
156,000 miles and standard transmission. Lately the truck has not been starting very well. When I got to start the truck all I hear is a click. After trying the ignition multiple times and depressing the gas pedal the truck will finally start. I had the battery and alternator checked and they are fine and the truck runs great once it gets going, so I am kind of at a loss as to what the problem is. Any help would be greatly appreciated.
2CARPRO JACK
  • 11,533 POSTS
Sounds like the starter. Next time it will not crank, check for power at the small wire on the starter. If it has and no crank, starter is bad.
JTMESS
I replaced the starter and the truck ran great for about a month. Now the truck engine will turn over but not start. Any thoughts?
2CARPRO JACK
  • 11,533 POSTS
Fuel pressure? Spark? Injector pulse?
