Tail and Parking Lights Not working?
BUCK211
  • 34 POSTS
To Cardiodoc:
Problem solved!
Man I am a special kinda stupid. LoL. I found my issue with the tail lights and it was such a simple solution. Turns out my problem wasn't from the 're wiring I did but from the connection between the black/yellow wires and where it connects at the firewall. Idk how I had it but I just started checking all my connections, and that wire was not connected properly at firewall. But, everything works again as it should.
Thank you Cardiodoc for the help, info, guidance on this. Also, what kinda vehicle was you looking for again? I'll check around my neck of the woods and see what I can find out for ya.
Thursday, December 3rd, 2020 AT 10:14 AM (Merged)
CARADIODOC
  • 34,367 POSTS
Dandy. Happy to hear it's solved and you're ready to buzz off into the sunset!
I'm looking for an '88 Grand Caravan with 15" wheels. I had one since new, but it's so rusty now, the carpet is the only thing holding the front and rear together. I used it for 15 years to drag around a tandem-axle enclosed trailer that's bigger and heavier than the van. I take it 55 miles to the Iola, WI Old Car Show swap meet where I repair and sell car radios. Going down a long steep hill, I couldn't hit 70 mph because of the wind resistance. When these came with factory 15" wheels, they also came with optional bigger brakes. I never hooked up or needed the trailer brakes.
Also, '88 was the last year before they came out with the computer-controlled 4-speed transmission. I have an '89. A '94, and a '95 with that transmission, but those would explode before I got to the end of my driveway if I tried to pull the trailer. I'm starting to see these vans on tv shows occasionally. At this point I'd even be happy with a rust-free body. Whatever I come up with is going to be stored indoors for the winter, and will have collector plates on it.
KILLERDODGE88
  • 1988 DODGE DAKOTA
  • 6 CYL
  • 208,000 MILES
My tail lights keep blowing fuses and this is how it happens I will turn on my head lights and then when I press my brakes the tail light and instrument panel fuse blows but my brake light fuse is fine then when this happened my turn signal stopped blinking but I dont know where my relay is located
  • 110,176 POSTS
The brake light and signals work from the same element in the bulb. Try this. Remove the bulbs from the light sockets. Turn the lights on and hit the brakes. Let me know if the fuse still blows.
BUCK211
  • 34 POSTS
Cardiodoc,
Omg man. My mom had an 88 Grand Caravan. It was the car I learned to drive in and the very 1st car of theirs my dad let me work on. Lmao. Small world, but man I will look around and see what I can find for ya. Hell it's least I could do for ya because you guys at 2carpros are AWESOME. Since buying this Kota, it quickly became my #1 visited website.
