Will not start
164,000 MILES • AUTOMATIC
MONIQUEL
All the lights come on but it will not start. It was clicking but now it is not. It did this one other time and then it started and have had no issues since so I just kind of forgot about it.
Jul 9, 2018 at 2:43 AM
  • 110,246 POSTS
First, a clicking when you turn the key usually indicates a weak battery. So, with that being said, the first thing we need to do is check it. Here is a link that describes how it is done:
If the battery checks good, then I would suspect a loose connection or a corrosion problem at the battery. Check to confirm the battery terminals are clean and tight. Here is a link which discusses how to properly check and clean battery terminals:
Since you had this happen before, there is a good chance that one of the cables is loose or corroded and finally lost connection. Or, the battery is just worn out and ready for replacement. If you are unable to check the battery yourself, follow these directions for removal and replacement. Remove the battery and have it load tested at a parts store. Most will do it for free.
https://www.2carpros.com/articles/how-to-replace-a-car-battery
And one last thing that may be of interest. Here is a link which discusses battery symptoms. It should help you make your determination.
https://www.2carpros.com/articles/symptoms-of-a-bad-car-battery
I hope this is helpful. Feel free to let me know if you have other questions or need help.
Jul 9, 2018 at 12:57 PM
