Starting
SATURNTECH9
  • 30,869 POSTS
OK keep us posted
Monday, February 13th, 2017 AT 9:17 PM
DOUGJR
  • 24 POSTS
I went out to find the right tool to tap on the starter, but I want to be sure I'm tapping in the right place. So where is it located?
Friday, February 17th, 2017 AT 12:50 PM
SATURNTECH9
  • 30,869 POSTS
Right on the large part of the starter lightly tap.
Friday, February 17th, 2017 AT 1:12 PM
DOUGJR
  • 24 POSTS
I'm not getting much help from my helper so some of your questions I unfortunately cannot answer at this time, but what about if I were to take the batt out and have it tested? If I do that isn't there a code I have to enter when I out the batt back in and if so where do I get that code?
Monday, February 20th, 2017 AT 11:47 AM
SATURNTECH9
  • 30,869 POSTS
I thought you already had the battery tested there is no code unless the radio locks. If it does you will have to contact the dealer to unlock it.
Monday, February 20th, 2017 AT 8:24 PM
DOUGJR
  • 24 POSTS
No, I'm sorry, I haven't had the batt tested by a pro yet. I tested it my self
Tuesday, February 21st, 2017 AT 8:44 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 54,217 POSTS
Use this test to check the battery
Please run this test and get back to us so we can continue helping you.
Best, Ken
Thursday, February 23rd, 2017 AT 3:32 PM
DOUGJR
  • 24 POSTS
I checked out the site you recommended but I can't do stage 2 because the starter will not turn over at all. What should I do?
Sunday, February 26th, 2017 AT 2:51 PM
KEN L
  • 54,217 POSTS
Lol sorry about that. You will need to remove the battery and try it to an auto parts store they will test it for free.
Sunday, February 26th, 2017 AT 6:26 PM
DOUGJR
  • 24 POSTS
Had batt tested and was told it was OK just low on charge, they are going to charge it and call me in the morn
Monday, February 27th, 2017 AT 12:27 PM
DOUGJR
  • 24 POSTS
Hey I just had a thought. (Yes that's what that noise was)! Since I have removed the battery and it is being charged by Interstate Batteries is there any way I can see if it will start using another car's battery? If so, how?
Monday, February 27th, 2017 AT 1:06 PM
SATURNTECH9
  • 30,869 POSTS
If you have a side post battery you can hook it up and crank it over. If you have battery voltage at battery cable at the starter and the purple wire to the the starter with the key in the start position. Then most likely you have a bad starter.
Monday, February 27th, 2017 AT 1:16 PM
DOUGJR
  • 24 POSTS
Just thought I would let you guys know that the wife got tired of seeing the car and know that it wasn't working so she had it towed to a mechanic and was told that the starter was bad
Tuesday, March 7th, 2017 AT 11:48 AM
KEN L
  • 54,217 POSTS
Yep that what we thought it was. Glad you could get it fixed please use 2CarPros. Com anytime we are here to help
Best, Ken
Tuesday, March 7th, 2017 AT 11:53 AM
SATURNTECH9
  • 30,869 POSTS
That's why I was asking you to tap on the starter while someone tried to start it. Glad to hear you got it figured out. Please tell all your friends about us.
Tuesday, March 7th, 2017 AT 9:36 PM
DOUGJR
  • 24 POSTS
Will do, count on it!
Wednesday, March 8th, 2017 AT 7:51 AM
