2003 Saturn L200 Will turn over strong, will not start, do
RMIRCOV
MEMBER
2003 SATURN L200
4 CYL
2WD
AUTOMATIC
150,000 MILES
Engine will turn over strong, yet will not start. I do not smell gas. Is it a timing belt issue, maybe jumped a bit?
Monday, December 1st, 2008 AT 5:58 PM
ROADSTER1929
MEMBER
Maybe a fuel pump or your not gettin any fire
coil, plugs, plug wires
SPONSORED LINKS
Monday, December 1st, 2008 AT 6:12 PM
MECHANIC
Do you hear the fuel pump come On when key at run position? If so
Check the fuel pressure with a fuel pressure gauge designed for your fuel system make sure its within specifications and comeback with the readings this is where we start.
