Alternator replacement?
STEVE SANCZEL
  • 2002 FORD ESCAPE
  • 6 CYL
  • 4WD
  • 113,000 MILES
Alternator light comes for a few minutes when engine is cold then goes out. How do I remove the existing alternator?
Tuesday, August 11th, 2020 AT 5:34 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
Check belt and belt tensioner
To remove the alternator
Disconnect negative battery cable.
Remove right side front drive halfshaft and intermediate shaft.
Remove right side lower splash shield screws and pin-type retainer. Remove 5 bolts and right front lower splash shield.
Rotate accessory drive belt tensioner clockwise.
Remove accessory drive belt from generator pulley.
Disconnect generator harness connector.
Remove upper and lower mounting bolts and generator from vehicle. Remove generator mounting bracket.
Remove generator electrical connectors.
To install, reverse removal procedure.
Tighten fasteners to specification
TCOOPER39
  • 2002 FORD ESCAPE
Electrical problem
2002 Ford Escape 6 cyl Front Wheel Drive Automatic
How do you change the alternator
Tuesday, August 11th, 2020 AT 5:35 PM (Merged)
DAVE H
  • 13,384 POSTS
REMOVAL & INSTALLATION
CAUTION:When battery is disconnected, vehicle computer and memory systems may lose memory data. Driveability problems may exist until computer systems have completed a relearn cycle. See appropriate COMPUTER RELEARN PROCEDURES article in GENERAL INFORMATION before disconnecting battery.
GENERATOR
Removal & Installation (2.0L Zetec)
Disconnect negative battery cable. Remove right front wheel and tire. Remove 5 bolts and right front lower splash shield. Rotate accessory drive belt tensioner clockwise. Remove accessory drive belt from generator pulley. Disconnect generator electrical connectors to voltage regulator. Remove B+ terminal cover, nut and disconnect electrical connector. Remove lower generator bolts.
NOTE:Prior to installing generator, ensure upper bolt is placed in generator.
Loosen upper generator bolt from engine. DO NOT remove upper bolt from generator. Insufficient clearance does not allow bolt to be completely removed. Move generator to rear of vehicle. Remove generator. To install, reverse removal procedure. Tighten fasteners to specification. See TORQUE SPECIFICATIONS.
Removal & Installation (3.0L Duratec)
Disconnect negative battery cable. Remove right side front drive halfshaft and intermediate shaft. See AXLE SHAFTS article in DRIVE AXLES. Remove right side lower splash shield screws and pin-type retainer. Remove 5 bolts and right front lower splash shield. Rotate accessory drive belt tensioner clockwise. Remove accessory drive belt from generator pulley. Disconnect generator harness connector. Remove upper and lower mounting bolts and generator from vehicle. Remove generator mounting bracket. Remove generator electrical connectors. To install, reverse removal procedure. Tighten fasteners to specification. See TORQUE SPECIFICATIONS.
GUMBY4914775
  • 2002 FORD ESCAPE
  • 6 CYL
  • 4WD
  • 100,000 MILES
What all do we have to remove to get alternator out and replace
BLUELIGHTNIN6
  • 16,542 POSTS
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_561.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_Noname2_142.jpg
2CP-ARCHIVES
  • 4,540 POSTS
  • 2002 FORD ESCAPE
  • 15,000 MILES
How do you change alternator? Pull motor? Its a V6
-Removal & Installation (3.0L Duratec)
JENSFIXORREPAIRDAILY
  • 2002 FORD ESCAPE
  • 6 CYL
  • FWD
  • 100 MILES
My brand new battery (Motorcraft) died after having it in my car for all of 2 days. My husband removed the aternator, took it and the replacement alternator to a car part place to have them checked. The one he removed was bad and the other was good so he replaced it. Next day after making sure the battery was fully charged I drove the car. All the while the battery light was on. Another day later the batter has been drained to empty. Is there a possibility there is something else that is keeping the alternator from doing it's job?
  • 110,071 POSTS
I would try a different alt. Also, there is a fuseable link between the bat and the alt. That sounds like the problem to me but I'm not there to check. Have that checked. NOTE: If the alt is good, the fuseable link will cause this because regardless of the alt's ability to charge to battery, it can't get power to it.
