Orifice tube and expansion valve location
CORY2427
  • 293 POSTS
Didn’t check them cause they hardly ever go bad on these cars so it could be that or can be evaporator core wouldn’t think it be that cause vacuum was good
Thursday, July 25th, 2019 AT 5:26 AM
STEVE W.
  • 15,322 POSTS
Hardly ever just means you might be the "lucky" owner.
Thursday, July 25th, 2019 AT 12:49 PM
CORY2427
  • 293 POSTS
What would be you most guess one of them or evaporator core bad or freezing idk what else to do thev pulled a vacuum it was good and charged it no leaks ac fan works so does radiator fan
Thursday, July 25th, 2019 AT 1:35 PM
STEVE W.
  • 15,322 POSTS
I would use a scan tool and test the actuators. I highly doubt it's any of the cores, if they were blocked the issue wouldn't go away.
Thursday, July 25th, 2019 AT 2:31 PM
CORY2427
  • 293 POSTS
I don’t have a scanner for that closest one would be 100 miles away what would be you other guess if it’s not cores or condenser or fan what other thing would make it go cd to hot and kick in and out at times
Thursday, July 25th, 2019 AT 3:00 PM
STEVE W.
  • 15,322 POSTS
Without a scan tool to test you could replace every part of the system and still not have it work. Sorry but that is a fact. At the moment it could be the temperature control doors, the fresh air door, the body control module, the temperature sensors or the main control head. The BCM and HVAC controller both are units that have to be programmed, The actuators also need a scan tool to reset them to the base positions if they are replaced.
Thursday, July 25th, 2019 AT 3:08 PM
CORY2427
  • 293 POSTS
What scan tool do I need
Thursday, July 25th, 2019 AT 3:23 PM
STEVE W.
  • 15,322 POSTS
There are a few that cover the VW/Audi Group vehicles, but those cars can be touchy when it comes to what works and what doesn't. There are a lot that can read the codes but many cannot read the odd VW long codes or connect to all the modules. About the best aftermarket unit is from Ross Tech.
Thursday, July 25th, 2019 AT 10:23 PM
