HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Ignition
No Spark
SPONSORED LINKS
No spark at the plugs?
PREV
1
2
3
NEXT
SEVENOF7
MEMBER
Cheack the eec reley under the hood drivers side
Wednesday, October 14th, 2020 AT 2:07 PM (Merged)
2CARPRO JACK
MECHANIC
Good call on the EEC relay
SPONSORED LINKS
PREV
1
2
3
NEXT
Please
login
or
register
to post a reply.
Related No Spark Content
Ignition No Spark Output?
Why Isn't There Sparks In Spark Plugs? Replaced Coil, Spark Plug Wires, Control Module On Disturbiter, Roder, And Still No Sparks. There...
Asked by
danieldelarosa
1989
FORD F-150
GUIDE
Ignition Spark Check
An engine's ignition system is responsible for igniting the fuel-air mixture inside the combustion chamber and when the ignition process stops the engine will not run....
No Spark
Well.I Got The Starter To Work. Now It Won't Fire. I Replaced The Plugs, Cap And Rotor Before I Got The Starter To Work. I'm...
Asked by
scorpio110103
5 IMAGES
1992
FORD F-150
No Spark Signal, Crank No Start
I Checked The Cam Position Sensor The Plug Connector Was Corroded I Unplugged It Bought A New One Spliced It Connected It, The Truck Used...
Asked by
Will Rey
1 ANSWER
2005
FORD F-150
No Spark
I Have A 1995 F-150 With A 4.9 L6 Motor. Engine Will Start Sometimes, Other Times It Wont. I Pulled A Spark Plug Off And Noticed That It...
Asked by
dkelley95
1995
FORD F-150
No Spark.
I Diagnosed The Truck With A No Start Problem Originally With No Spark. After A Few Test I Found That The Vehicle Would Run If I Took The In...
Asked by
sdecker
1 ANSWER
1 IMAGE
1987
FORD F-150
VIEW MORE
SPONSORED LINKS
Ignition Coil System Test Repair - All Cars
Ignition System Testing
Crankshaft Sensor Symptoms
Online car repair manuals
