Vehicle starts and immediately stalls intermittently
144,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
AL514
  • 5,697 POSTS
Vehicle starts and immediately stalls intermittently, of course this is the same Impala i have been having all kinds of problems with, one after the other. *No check engine light. I am going to go through the motions of regular checks (fuel pressure, sensor checks, scans etc). this car has a dual hall effect crank sensor (3x and 18x). The book reads that the lose of either of these signals will prevent the car from restarting at all. It also has a camshaft position sensor that controls SFI. The cam sensor signal can be lost and the vehicle will be able to be restarted and run in Limp in mode. I think I am dealing with a fuel pressure issue although I have not got to this test yet (i am getting there). My question is, I pulled the vacuum line off the fuel pressure regulator and had no change in engine performance, even with throttle snap test. Just wondering if I should chase the cam sensor next if my fuel pressure tests come out okay (considering I have a no code condition)? This stalling issue will happen cold or hot and car will start right back up and run fine. But the stalling is happening more often now but only on start up. Changing the crank sensor on these is a lot of work considering it is behind the harmonic balancer. Any tips my friends?
Sep 23, 2016 at 1:08 AM
WRENCHTECH
  • 20,760 POSTS
Just remember, any testing you do has to be done while the problem is present.
Are you sure you do not have any security indicators when this happens?
Mar 12, 2021 at 1:24 AM
AL514
  • 5,697 POSTS
no, I have not had any security lights on. The problem is getting worse, so I do not suspect any security systems causing this.
WRENCHTECH
  • 20,760 POSTS
Those are the exact symptoms of Passlock activation.
AL514
  • 5,697 POSTS
I have not had any of these problems before, should I pull the security fuse here or whats my next check for pass-lock, I am not trained on Chevrolet's security systems.
WRENCHTECH
  • 20,760 POSTS
The first thing is look for the indicator which may be a very small LED flashing. Diagnosing the system will require a professional, bidirectional scan tool.
AL514
  • 5,697 POSTS
I guess anything is possible at this point. I am finding this car has been hacked, there are cut wires and an ACC module tie rapped up under the dash,. Someone has made a mess under here =/. Im assuming like a lot of other cars this security system runs through the radio or such? Looking like a nightmare so far.
AL514
  • 5,697 POSTS
can I bypass this system some how? it is a real mess under the dash.
WRENCHTECH
  • 20,760 POSTS
I am sorry no you cant.
AL514
  • 5,697 POSTS
okay, so there is a way to turn the PASSLOCK system off through the Radio settings, I have no light on my dash for any locking or security system being on.
AL514
  • 5,697 POSTS
and also I thought the PASS LOCK system caused a no crank situation?
WRENCHTECH
  • 20,760 POSTS
You cannot shut off Passlock and a Passlock failure will cause an immediate start and stall.
AL514
  • 5,697 POSTS
is Passlock light same light as change engine oil light on dash ? or different light all together? you mention small blinking LED?
Mar 12, 2021 at 1:25 AM
AL514
  • 5,697 POSTS
Pass-lock is part of ignition switch correct? can I just replace the switch if this is the problem? These GM's are starting to be a real pain lately. I am having to replace parts every month now after 140,000 miles.
WRENCHTECH
  • 20,760 POSTS
The ignition switch may or may not be the problem. A new switch will have to be programmed after installation.
AL514
  • 5,697 POSTS
I have not installed any new parts yet, and every other part I have installed was bad, ie MAF etc. I just have not dealt with this pass-lock system as of yet.
WRENCHTECH
  • 20,760 POSTS
There are many independent shops that have the equipment and it costs considerably more than $2,000.00. The diagnostic charge would probably be a lot less than what guessing would cost .
AL514
  • 5,697 POSTS
I'm trying to learn whats involved with the passlock, is there more than just the BCM and ignition switch?
WRENCHTECH
  • 20,760 POSTS
The theft deterrent system has been incorporated into the Body Control Module (BCM) . The theft deterrent system prevents the vehicle operation if the correct key is not used in order to start the vehicle. The ignition key turns the ignition lock cylinder. The cylinder rotation produces an analog voltage code in the PASSLOCK sensor. This voltage code is received by the BCM. The BCM compares the voltage code to the previously learned voltage code. If the codes match, a class 2 message is sent from the BCM to the Powertrain Control Module (PCM) . The message enables the fuel injectors and the crank relay.
The design of the PASSLOCK system is to prevent vehicle theft by disabling the engine unless the ignition lock cylinder rotates properly by engaging the correct ignition key. The system is similar in concept to the passkey system. However, the PASSLOCK system eliminates the need for a key mounted resistor pellet.
The components of the PASSLOCK system are as follows:
The ignition lock cylinder
The ignition switch
The PASSLOCK sensor
The body control module (BCM)
The SECURITY indicator
The powertrain control module (PCM)
WRENCHTECH
  • 20,760 POSTS
The Passlock system may not even be your problem. You should be checking your fuel pressure with a gauge also.
  • 55,721 POSTS
Hi Al,
Yes I would hang a fuel pressure gauge on there and check if you have spark while the engine is not running.
Here is a couple guides that will help you. please get back yo us with the results.
and
Best, Ken
AL514
  • 5,697 POSTS
There has not been a "no run condition". Its just been, vehicle starts for two seconds, then stalls but fires right up on next crank. Almost like a fuel pressure/volume issue. Which I am going to check. I realize Pass-lock is a possibility, but at this point I am not getting any security lights. I have no issues diagnosing a crank, no start situation. Been through a million of those, this is just the first time i have ever had any possible pass-lock issues. I always start with basics, ie fuel pressure, spark etc. If something leads me in the direction of a security problem, that is different. Then I will go that way. Its just a system I have not had experience or problems with in the past. Plus the car has not died on me yet, it does start on second crank and run fine. Does not stall while driving at all, in fact it runs very well besides this slight starting problem. I have seen shorted cam sensors cause this problem without setting any TDC's. Will post what I find.
  • 55,721 POSTS
It could be a problem with the IAC like is it running slow. I have seen where a weak IAC will cause the problem you are describing.
AL514
  • 5,697 POSTS
could be, but it idles fine and there are no problems once its running, plus the stall condition only happens once and awhile. I'm buying to new scantool and some other gear. So I'm going to just start testing everything, ive never graphed an IAC, I should just be looking for it to close as the throttle opens correct? or is there a better test for it? This car is just getting old and needs some tlc.
  • 55,721 POSTS
It will open the idle air port, look at the plunger of the valve. It should move quickly in and out when the key in turned on.
WRENCHTECH
  • 20,760 POSTS
I don't advise doing that with the IAC removed. It will over extend and you'll be buying a new IAC.
AL514
  • 5,697 POSTS
I have seen someone over extend and IAC before like that, that's why I was thinking of graphing it to see the voltage reading atleast. it has not had an idling problem, I still think its going to end up being a fuel pressure problem, if I ever get time to work on the thing. Of course it got to be fixed before I drive it for 12hours to NC. I think with my new scan tool I can watch live data of idle control. But I did see a mechanic pull the plunger out of the IAC, my jaw dropped, and we had the pleasure of buying a new one when the car actually needed a new intake gasket.
AL514
  • 5,697 POSTS
of course it was the parts guy that pulled the IAC apart, thinking he knew what he was doing. ruined the whole thing
AL514
  • 5,697 POSTS
if I throw a vacuum gauge on this thing I should have around 12psi I believe at idle? or was it more, cant remember. going to check for a vacuum leak as well. I would think something would set a code by now, but nothing so far. also another funny thing, the last time it set a code, it couldn't read any freeze frame data. I thought that was alittle suspicious
  • 55,721 POSTS
Hey,
Did you ever get the problem fixed?
Best, Ken
