2001 Chevy Impala Car will not start
DAVISCF
  • 2001 CHEVROLET IMPALA
  • 6 CYL
  • FWD
  • 144,400 MILES
When recently driving my vehicle, I've noticed that the Temperature gauge was directly running on the hot side until the car basically, turn its self off. I then checked for coolant and it was not low. I touched the engine block and it was not ho either. Checked the radiator top and that was cold. Once the vehicle cooled down I begun to drive it some more. Next time when I stopped the car begun to create smoke coming from the engine. I then called a tow truck an got it towed to my house. The next morning I attempted to start the car but it would not start. Any suggestions. Thanks.
Tuesday, April 1st, 2008 AT 9:19 AM
RHALL77
  • 3,361 POSTS
First thing is to check and see if you have fuel pressure and spark
Tuesday, April 1st, 2008 AT 9:45 AM
DAVISCF
I would hate to sound ignorant but how would I check for that. :Shock:
Tuesday, April 1st, 2008 AT 9:47 AM
RHALL77
  • 3,361 POSTS
You would need to obtain a fuel pressure gauge and a spark tester. Fuel pressure port is located behind the power steering pump. Fuel pressure should be around 55-60 psi
Tuesday, April 1st, 2008 AT 12:31 PM
DAVISCF
Thanks for your assistance I will go ahead and test out what you recommended. Thanks again ! :)
Tuesday, April 1st, 2008 AT 3:13 PM
