2001 Impala will not start
BDDIANA
I have a 2001 Chevy Impala with 230,000 miles on it. Every so often it will not start. If you disconnect the battery and reconnect it it starts. We thought the pass lock theft system was going bad so we had a new ignition switch put in but it still will not start. And now the power door locks will not work with the switch or the key fob. When the car will not start, the interrior lights don't work either. Any suggestions?
Thanks,
Nov 4, 2007 at 7:50 AM
BMRFIXIT
  • 19,053 POSTS
[quote:ec7c6664d8="bddiana"]I have a 2001 Chevy Impala with 230,000 miles on it. Every so often it will not start. If you disconnect the battery and reconnect it it starts. We thought the pass lock theft system was going bad so we had a new ignition switch put in but it still will not start. And now the power door locks will not work with the switch or the key fob. When the car will not start, the interrior lights don't work either. Any suggestions?
Thanks,[/quote:ec7c6664d8]
have the BCM tested or you may need one
if you can get the code s from the BCM
it will help
is the radio working windows too
......... BCM.........
good luck
Nov 4, 2007 at 11:47 AM
BDDIANA
BMRFIXIT,
The radio and windows are still working. I've never tried to turn them on when the car acts up. I'll take your advise and have the bcm checked. Thanks :)
Nov 4, 2007 at 9:08 PM
