Does it run with the gas can and the electric pump?
If it does, then you need a fuel pump.
If it does not then you will need to use a test light or noid light on the injectors or one injector to see if the ECM is commanding the injectors to fire.
Thursday, April 22nd, 2021 AT 1:40 PM
