2004 Ford F250 ENGINE MISSING
2004 FORD F-250
21,400 MILES • V8 • 4WD • AUTOMATIC
MAZZOTTIJ
this condition starts after runing truck for 5 to 10 minutes
WHEN STEPPING ON FUEL PEDDEL AND RELEASE TAIL PIPE HAS LITTLE BACK FIRE, ENGINE COMPUTER CODE IS P1152 AND COMES UP WITH (1)DEFINITION LACK OF 2 SWITHCES BANK 2 SENSOR, RICH EXPLANATION 2
(2) AAECM DETECTED 02 SENSOR AT IS RICH LIMIT
proboble cause
1, fuel preasuer high
2, egr stuck open
3, engiine mechanical condition
which one do I go for first when trying to repair
May 29, 2010 at 1:53 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Thank you for the donation it is very much appreciated.
Here are the defs I have for P1152
P1152 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 2
P1152 O2 Sensor Heater Circuit Low Voltage (Bank 2 Sensor 1)
P1152 Lack Of HO2S-21 Switch Indicates Rich
Ok, First thing to check is the Fuses for the Heated O2 Sensors.
Next would be to either put the vehicle on a Scanner capable of showing the wave forms of the sensor or just replacing the sensor.
Also are there any other drivability problems?
May 29, 2010 at 10:49 AM
