This just happened again the other day and this time the misfire will not quit. I went down and bought a new coil for #8 cylinder and replaced this with no luck. I took this coil back thinking it was a bad coil and replaced it again. The truck ran fine for about 2 miles and dropped #8 cylinder again.
I did not replace the one spark plug thinking this might cause a check engine light with only 1 new plug. The plugs have about 40-50,000 miles on them.
This same problem happened about 4 months ago and I replaced the coil on #7 and everything worked fine. However, this is not working this time.
Any ideas as I need help.
Regards, Brad
Wednesday, October 15th, 2008 AT 6:12 AM
