1987 Jeep Wrangler Water Pump
CONFUSSEDAGAIN
  • 1987 JEEP WRANGLER
The water pump keeps locking up. Within just a few minutes of installing it. What could be causing this
Tuesday, November 6th, 2007 AT 8:41 PM
MIKE H R
  • 3,094 POSTS
What do you mean? Does the water pump just not turn after you had installed it? There could be a couple of reasons. Water pump bad. Something inside binding up the pump or the wrong water pump for the engine. Disconnect the belt and remove, try moving the water pump pulley back and forth, watch it sometime the edges are sharp. It it turns a little and stops then ther could be something loose inside locking it up.
Thursday, November 8th, 2007 AT 9:40 PM
