2001 Jeep Wrangler Coolant Leak
2001 JEEP WRANGLER
93,000 MILES • 6 CYL • 4WD • MANUAL
GIGGY09
I'm leaking engine coolant through my heater core. My radiator has been tested and no leaks have been found. however, I can see coolant dripping from the heater core into my floor boards in the car and onto the ground outside the car. The engine has been overheating and I constantly need to refill the radiator to keep the engine cool.
My question is, how do I stop the leak through the heater core? I know I can bypass it by connecting the hoses but that leaves me without heat in my car. Please help me out if you can. Thanks!
Dec 16, 2009 at 3:04 AM
MICKEY-D
  • 304 POSTS
You have two options. Bypass the heater core, or replace it. Sorry.
Dec 17, 2009 at 6:53 AM
GIGGY09
Thanks for your reply! Just for reference...roughly how much would it cost to replace the heater core? I've been hearing anything from $200-$400.
Dec 17, 2009 at 7:11 AM
DOCFIXIT
  • 18,828 POSTS
Try some Aluminaseal small tube silver flakes. parts house will have look at the additive section. Tube on a card works good make stop leak.
Repair is 4.3 hrs plus core dash needs to come out so more like $700
Dec 17, 2009 at 7:27 AM
