1998 Jeep Wrangler Coolant Leak
TARHEEL06
I have a 98 Wrangler that appears to be leaking coolant internally. The vehicle also idles low for the first few minutes after turning it on. Are these problems related and what could be the cause of the leak?
Jul 28, 2006 at 7:47 AM
MIKEYBDMAN
  • 623 POSTS
Do you know where the water is going? Oil pan, or being burned?
Either way, if it is the V6 engine you have, then it is probably a leaking intake manifold gasket or possibly a head gasket.
If you have the 4 cylinder, then it most likely is your head gasket.
Jul 28, 2006 at 12:54 PM
DEMEARSJR
  • 110 POSTS
Check your oil cap and your exhaust.
White smoke or milky looking under the cap.
Jul 29, 2006 at 3:29 AM
TARHEEL06
[quote:8338d0adde="tarheel06"]I have a 98 Wrangler that appears to be leaking coolant internally. The vehicle also idles low for the first few minutes after turning it on. Are these problems related and what could be the cause of the leak?[/quote:8338d0adde]
Do you think the low idle could be related to the coolant leak a la the o2 sensor perhaps?
Aug 1, 2006 at 5:22 AM
MIKEYBDMAN
  • 623 POSTS
[quote:7cf94ca289="tarheel06"][quote:7cf94ca289="tarheel06"]I have a 98 Wrangler that appears to be leaking coolant internally. The vehicle also idles low for the first few minutes after turning it on. Are these problems related and what could be the cause of the leak?[/quote:7cf94ca289]
Do you think the low idle could be related to the coolant leak a la the o2 sensor perhaps?[/quote:7cf94ca289]
I would say the two problems are probably not related. However, if you dont address the coolant leak, you may end up doing more damage to the engine.
Aug 1, 2006 at 9:11 AM
Suggested Repair
Check the oil cap and exhaust for milky oil or white smoke to confirm an internal coolant leak. On the V6, inspect the intake manifold gasket and possibly the head gasket; on the 4-cylinder, the head gasket is the most likely cause. The low idle is probably unrelated, but the leak should be repaired promptly to avoid further engine damage.
Conversation Summary
The owner of a 1998 Jeep Wrangler reports an apparent internal coolant leak and a low idle for the first few minutes after startup, and asks whether the issues are related, possibly through an oxygen sensor. Experts advise checking where the coolant is going by looking for milky residue under the oil cap or white exhaust smoke. They say a V6 is likely leaking at the intake manifold gasket or head gasket, while a 4-cylinder most likely has a head gasket leak. The low idle is considered probably unrelated, but the leak should be addressed to prevent further engine damage.
