changed thermostat and heat improved dramatically. filled coolant up as well. I think i will change the CTS sensor as well cause its close to the thermostat and that was stuck open. thanks for the input
brklynkid
IS coolant full? the first area to get starved is the heater core when the fluid drops.
Regarding A/C:
MAy be low on freon or have a leak. This system originally came with R12, which is very hard to get and expensive when you find it. Either conver to R134a or leave it alone. A/C can be a real heartbreak. Unless you really need it, and are prepare for the potential of spending a few thousand dollars, I wouldn't touch it.[/quote]
Jan 7, 2007 at 10:56 AM
