unseen coolant leak and heater problems
2007 JEEP WRANGLER
118,000 MILES • 3.8L • 6 CYL • 4WD • MANUAL
PORTLANDJ25
I have had a coolant leak for quite some time. It is coming from the top of the motor somewhere and I do not have a pressure tester to check where it sould be coming from. Is this a common issue for this make and model? And this morning on my way to work I noticed that I had me heat on but it was only blowing cold air. It worked yesterday but now apparently it isn't. There was no fore warning of this just apparently stopped. What can I do to fix both of these issues? Thank you.
Feb 25, 2015 at 11:30 PM
HMAC300
  • 48,601 POSTS
Coolant leaks can occur for various reasons, including a damaged hose, a faulty radiator, a failing water pump, or a cracked engine block.
Please go over this guide as well.
https://www.2carpros.com/articles/car-is-leaking-coolant
Please go over these guides and get back to us.
Feb 25, 2015 at 11:50 PM
PORTLANDJ25
I have filled it before but never had problems with the heater before. I found out the water pump is leaking thanks to the guide. That should fix the heater problem as well?
Feb 26, 2015 at 12:12 AM
HMAC300
  • 48,601 POSTS
You betcha!
Feb 26, 2015 at 1:34 AM
