1997 Isuzu Rodeo No Fuel to Engine
ISUZU
ABERNETHY
i have a 1997 isuzu rodeo with over 200,000 miles its a 6 cilinder 2wheel drive. its not geting gas into the engine we replaced the fuel filter and it still wont start how difficult will it be for me to drop the gas tank and try to replace the fuel pump myself? and how expensive? if i cant do it the roughtly how much on average to take it to a mechanic?
Jun 21, 2006 at 2:10 PM
SYNCRAIT
  • 235 POSTS
its not terribly hard if you have some spare time a dry area and means of getting the car off the ground a bit..... the only problems you might run into is getting the locking ring off the sending unit but also make sure you disconnect all hoses prior to dropping the tank to make sure you dont pinch and puncture one... good luck :)
ps.... patience is key when working with the gas tank not only because of the obvious reasons but just about every thing involved costs a good chunk of change...
Jun 22, 2006 at 11:22 PM
Suggested Repair
A tank drop to replace the fuel pump is doable with time, a dry work area, and a way to raise the vehicle. Disconnect all hoses before lowering the tank so they are not pinched or punctured, and expect the sending-unit locking ring to be the main difficulty. Work patiently because the related parts are costly. No specific parts or labor prices were given.
Conversation Summary
The owner of a 1997 Isuzu Rodeo with over 200,000 miles said the engine was not getting fuel and still would not start after the fuel filter was replaced. They asked how hard and expensive it would be to drop the tank and replace the fuel pump, and what a mechanic might charge. The expert said the job is not terribly hard with time, a dry area, and a way to raise the vehicle, but warned to disconnect all hoses first and that removing the sending-unit locking ring can be difficult. No dollar amounts were provided.
