1997 Isuzu Rodeo No Start After Sitting
ISUZU
CHESTER306
1997 Isuzu Rodeo 3.2 v, 50,000 mi
This vehicle has sat for seven years with fuel in the system. I have replace the fuel pump, tank and in-line filter. I now have good fuel pressure up to the fuel header/injectors but cannot get it to run. I have recently removed the injectors and just as I suspected they are dirty from old fuel. Is there any way to clean and check there operation while out of the vehicle? I would like to bypass the $150.00 ea. expense of new ones if possible.
Sep 4, 2007 at 2:03 AM
2CARPRO JACK
  • 11,533 POSTS
You verified spark? After that long the tank needs to be drained and new fuel and possibly a stabilizer added.After you verify spark, get a "noid" light and be sure the injectors are getting pulse
Dec 28, 2007 at 11:24 PM
Suggested Repair
Verify spark, use fresh fuel (and a stabilizer if needed), and confirm the injectors are receiving a pulse with a noid light before replacing them.
Conversation Summary
A 1997 Isuzu Rodeo 3.2 that sat for seven years has good fuel pressure after the pump, tank, and inline filter were replaced, but it still will not run. The owner found dirty injectors and asked whether they can be cleaned and tested off the vehicle. The expert advised verifying spark, using fresh fuel with a possible stabilizer, and checking injector pulse with a noid light.
